Discourse Structure Extraction from Pre-Trained and Fine-Tuned Language Models in Dialogues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chuyuan Li
Patrick Huber
  • Fonction : Auteur
  • PersonId : 1237763
Wen Xiao
  • Fonction : Auteur
  • PersonId : 1237764
Maxime Amblard
Giuseppe Carenini
  • Fonction : Auteur
  • PersonId : 1237765
Discourse processing suffers from data sparsity, especially for dialogues. As a result, we explore approaches to build discourse structures for dialogues, based on attention matrices from Pre-trained Language Models (PLMs). We investigate multiple tasks for fine-tuning and show that the dialogue-tailored Sentence Ordering task performs best. To locate and exploit discourse information in PLMs, we propose an unsupervised and a semi-supervised method. Our proposals thereby achieve encouraging results on the STAC corpus, with F 1 scores of 57.2 and 59.3 for the unsupervised and semisupervised methods, respectively. When restricted to projective trees, our scores improved to 63.3 and 68.1.
lisa_eacl23_codi_submission.pdf (1.67 Mo) Télécharger le fichier
hal-04031267 , version 1 (15-06-2023)
Paternité
Chuyuan Li, Patrick Huber, Wen Xiao, Maxime Amblard, Chloé Braud, et al.. Discourse Structure Extraction from Pre-Trained and Fine-Tuned Language Models in Dialogues. European Chapter of the Association for Computational Linguistics (EACL), May 2023, Dubrovnik, Croatia. pp.2562-2579. ⟨hal-04031267⟩
39 Consultations
57 Téléchargements
