Ants and bracket generating distributions in dimension 5 and 6 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2023
We consider a mechanical system of three ants on the floor, which move according to two independt rules: Rule A - forces the velocity of any given ant to always point at a neighboring ant, and Rule B - forces the velocity of every ant to be parallel to the line defined by the two other ants. We observe that Rule A equips the 6-dimensional configuration space of the ants with a structure of a homogeneous (3,6) distribution, and that Rule B foliates this 6-dimensional configuration space onto 5-dimensional leaves, each of which is equiped with a homogeneous (2,3,5) distribution. The symmetry properties and Bryant-Cartan local invariants of these distributions are determined. In the case of Rule B we study and determine the singular trajectories (abnormal extremals) of the corresponding distributions. We show that these satisfy an interesting system of two ODEs of Fuchsian type.
hal-04032758 , version 1 (16-03-2023)
Andrei Agrachev, Pawel Nurowski. Ants and bracket generating distributions in dimension 5 and 6. Automatica, 2023, 147. ⟨hal-04032758⟩
16 Consultations
0 Téléchargements
