Configuration Optimization with Limited Functional Impact - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dealing with a large configuration space is a complex task for developers, especially when configurations must comply with both functional constraints and non-functional goals. In this paper, we introduce an approach to optimize any set of performance indicators for an existing configuration, while meeting functional requirements. The efficiency of this approach is assessed by exhaustively optimizing a configurable system, and by analyzing how the algorithm navigates through the configuration space. This approach proves especially efficient at optimizing configurations through a minimal number of changes, thus limiting the impact on their functional behavior.
CAISE23.pdf (2.84 Mo) Télécharger le fichier
hal-04034888 , version 1 (17-03-2023)
  • HAL Id : hal-04034888 , version 1
Edouard Guégain, Amir Taherkordi, Clément Quinton. Configuration Optimization with Limited Functional Impact. CAISE 2023 - 35th International Conference on Advanced Information Systems Engineering, Jun 2023, Zaragoza, Spain. ⟨hal-04034888⟩
67 Consultations
106 Téléchargements
