Interpretation of Parareal as a Two-level Additive Schwarz In Time Preconditioner and Its Acceleration with GMRES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2023
We describe an interpretation of parareal as a two-level additive Schwarz preconditioner in the time domain. We show that this twolevel preconditioner in time is equivalent to parareal and to multigrid reduction in time (MGRIT) with F-relaxation. We also discuss the case when additional fine or coarse propagation steps are applied in the preconditioner. This leads to procedures equivalent to MGRIT with FCF-relaxation and to MGRIT with F(CF) 2-relaxation or overlapping parareal. Numerical results show that these variants have faster convergence in some cases. In addition, we also apply a Krylov subspace method, namely GMRES (Generalized Minimal Residual), to accelerate the parareal algorithm. Better convergence is obtained, especially for the advection-reaction-diffusion equation in the case when advection and reaction coefficients are large.
PaperOnParareal.pdf (1.05 Mo) Télécharger le fichier
hal-04038459 , version 1 (20-03-2023)
  • HAL Id : hal-04038459 , version 1
Van-Thanh Nguyen, Laura Grigori. Interpretation of Parareal as a Two-level Additive Schwarz In Time Preconditioner and Its Acceleration with GMRES. Numerical Algorithms, 2023. ⟨hal-04038459⟩
129 Consultations
122 Téléchargements
