Inverse problem regularization with hierarchical variational autoencoders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose to regularize ill-posed inverse problems using a deep hierarchical variational autoencoder (HVAE) as an image prior. The proposed method synthesizes the advantages of i) denoiser-based Plug \& Play approaches and ii) generative model based approaches to inverse problems. First, we exploit VAE properties to design an efficient algorithm that benefits from convergence guarantees of Plug-and-Play (PnP) methods. Second, our approach is not restricted to specialized datasets and the proposed PnP-HVAE model is able to solve image restoration problems on natural images of any size. Our experiments show that the proposed PnP-HVAE method is competitive with both SOTA denoiser-based PnP approaches, and other SOTA restoration methods based on generative models.
hal-04038644 , version 1 (21-03-2023)
Jean Prost, Antoine Houdard, Andres Almansa, Nicolas Papadakis. Inverse problem regularization with hierarchical variational autoencoders. IEEE International Conference on Computer Vision (ICCV'23), Oct 2023, Paris, France. ⟨hal-04038644⟩
61 Consultations
0 Téléchargements
