Degenerate Cahn-Hilliard equation: From nonlocal to local - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2023
There has been recently an important interest in deriving rigorously the Cahn-Hilliard equation from the nonlocal equation, also called aggregation equation. So far, only non-degenerate mobilities were treated. Since we are motivated by models for the biomechanics of living tissues, it is useful to include degenerate motilities. In this framework, we present a new method to show the convergence of the nonlocal to the local degenerate Cahn-Hilliard equation. The method includes the use of nonlocal Poincar\'e and compactness inequalities.
hal-04043519 , version 1 (23-03-2023)
Charles Elbar, Jakub Skrzeczkowski. Degenerate Cahn-Hilliard equation: From nonlocal to local. Journal of Differential Equations, 2023, 364, pp.576-611. ⟨10.1016/j.jde.2023.03.057⟩. ⟨hal-04043519⟩
26 Consultations
0 Téléchargements
