Modeling, evaluating, and orchestrating heterogeneous environmental leverages for large-scale data center management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of High Performance Computing Applications Année : 2023
Data centers are very energy-intensive facilities that can generate various environmental impacts. Numerous energy, power, and environmental leverages exist and can help cloud providers and data center managers to reduce some of these impacts. But dealing with such heterogeneous leverages can be a challenging task that requires some support from a dedicated framework. This article presents a new approach for modeling, evaluating, and orchestrating a large set of technological and logistical leverages. Our framework is based on leverages modeling and Gantt chart leverages mapping. First experimental results based on selected scenarios show the pertinence of the proposed approach in terms of management facilities and potential impacts reduction.
Modeling_evaluating_and_orchestrating_heterogeneous_environmental_leverages_for_large_scale_data_centers_management.pdf (724.51 Ko) Télécharger le fichier
Licence : CC BY SA - Paternité - Partage selon les Conditions Initiales
hal-04047008 , version 1 (04-10-2023)
Paternité
Vladimir Ostapenco, Laurent Lefèvre, Anne-Cécile Orgerie, Benjamin Fichel. Modeling, evaluating, and orchestrating heterogeneous environmental leverages for large-scale data center management. International Journal of High Performance Computing Applications, 2023, 37 (3-4), ⟨10.1177/10943420231172978⟩. ⟨hal-04047008⟩
307 Consultations
62 Téléchargements
