New estimation of Sobol' indices using kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this work, we develop an approach mentioned by da Veiga and Gamboa in 2013. It consists in extending the very interesting point of view introduced in \cite{gine2008simple} to estimate general nonlinear integral functionals of a density on the real line, by using empirically a kernel estimator erasing the diagonal terms. Relaxing the positiveness assumption on the kernel and choosing a kernel of order large enough, we are able to prove a central limit theorem for estimating Sobol' indices of any order (the bias is killed thanks to this signed kernel).
Noyaux_compact_hal.pdf (455.43 Ko) Télécharger le fichier
hal-04052837 , version 1 (30-03-2023)
Sébastien Da Veiga, Fabrice Gamboa, Agnès Lagnoux, Thierry Klein, Clémentine Prieur. New estimation of Sobol' indices using kernels. 2023. ⟨hal-04052837⟩
47 Consultations
73 Téléchargements
