Impact of $\Delta \textrm{B}_0$ field imperfections correction on BOLD sensitivity in 3D-SPARKLING fMRI data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Static and dynamic ∆$B_0$ field imperfections are detrimental for fMRI applications as they degrade the temporal SNR (tSNR) and the sensitivity to the BOLD contrast. In this work we propose an experimental protocol for field imperfection monitoring and correction on 3D-SPARKLING fMRI data using the Skope Clip-on field camera in an alternative setting challenging its long TR constraint. We demonstrate the viability of our protocol and the reproducible gain in image quality, tSNR and retinotopic maps when correcting static and dynamic field imperfections on resting-state and taskbased fMRI data for 3 healthy volunteers.
Zaineb_ISMRM_2023.pdf (3.38 Mo) Télécharger le fichier
hal-04052904 , version 1 (11-04-2023)
Paternité
  • HAL Id : hal-04052904 , version 1
Zaineb Amor, Caroline Le Ster, Chaithya Giliyar Radhakrishna, Guillaume Daval-Frérot, Bertrand Thirion, et al.. Impact of $\Delta \textrm{B}_0$ field imperfections correction on BOLD sensitivity in 3D-SPARKLING fMRI data. ISMRM & ISMRT 2023 - Annual Meeting & Exhibition - Annual Meeting of the International Society for Magnetic Resonance in Medicine, International Society for Magnetic Resonance in Medicine, Jun 2023, Toronto, Canada. ⟨hal-04052904⟩
60 Consultations
25 Téléchargements
