Explanation: from ethics to logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of the Japan Association for Philosophy of Science Année : 2023
When a decision, such as the approval or denial of a bank loan, is delegated to a computer, an explanation of that decision ought to be given with it. This ethical need to explain the decisions leads to the search for a formal definition of the notion of explanation. This question meets older questions in logic regarding the explanatory nature of proof.
explanation.pdf (589.17 Ko) Télécharger le fichier
bisectors2.pdf (3.86 Ko) Télécharger le fichier
catsanddogs.pdf (4.63 Ko) Télécharger le fichier
hal-04055141 , version 1 (01-04-2023)
hal-04055141 , version 2 (02-07-2023)
hal-04055141 , version 3 (01-09-2023)
hal-04055141 , version 4 (23-09-2023)
hal-04055141 , version 5 (16-01-2024)
Paternité
Gilles Dowek. Explanation: from ethics to logic. Annals of the Japan Association for Philosophy of Science, 2023, 32, pp.16. ⟨hal-04055141v5⟩
83 Consultations
42 Téléchargements
