Generative modeling of extremes with neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate new parametrizations based on neural networks in order to approximate and sample multi-variate extreme values, especially in the case of heavy-tailed distributions. We discuss two approaches. First, transformations of Feedforward neural networks based on Rectified linear units (ReLU) are used. An analysis of the uniform error between the extreme quantile and its GAN approximation is provided, and shows that second-order parameters of the marginal data distributions play an important role. Second, eLU based NN are used, to efficiently get rid of the bias term in tails approximation, in the presence of arbitrary high-order parameters. These results are illustrated on synthetic and real data.
Fichier non déposé
hal-04057231 , version 1 (04-04-2023)
  • HAL Id : hal-04057231 , version 1
Michaël Allouche, Stéphane Girard, Emmanuel Gobet. Generative modeling of extremes with neural networks. 2023 - Accelerating Generative Models and Nonconvex Optimisation Workshop, The Alan Turing Institute, Mar 2023, London, United Kingdom. ⟨hal-04057231⟩
62 Consultations
0 Téléchargements
