A variance reduction strategy for numerical random homogenization based on the equivalent inclusion method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2023
Using the equivalent inclusion method (a method strongly related to the Hashin-Shtrikman variational principle) as a surrogate model, we propose a variance reduction strategy for the numerical homogenization of random composites made of inclusions (or rather inhomogeneities) embedded in a homogeneous matrix. The efficiency of this strategy is demonstrated within the framework of two-dimensional, linear conductivity. Significant computational gains vs full-field simulations are obtained even for high contrast values. We also show that our strategy allows to investigate the influence of parameters of the microstructure on the macroscopic response. Our strategy readily extends to three-dimensional problems and to linear elasticity. Attention is paid to the computational cost of the surrogate model. In particular, an inexpensive approximation of the so-called influence tensors (that are used to compute the surrogate model) is proposed.
hal-04058543 , version 1 (04-04-2023)
Paternité
Sébastien Brisard, Michael Bertin, Frederic Legoll. A variance reduction strategy for numerical random homogenization based on the equivalent inclusion method. Computer Methods in Applied Mechanics and Engineering, 2023, 417, pp.116389. ⟨10.1016/j.cma.2023.116389⟩. ⟨hal-04058543⟩
52 Consultations
0 Téléchargements
