Generalized Homogeneous Unit Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The methodology of the unit sliding mode control design (known since 1970s) for linear MIMO (Multiply Inputs Multiply Outputs) systems is revised based on the concept of the generalized homogeneity. The conventional restriction about a consistency of the number of control inputs with the dimension of the sliding surface is eliminated. A simple procedure for control parameters tuning is developed. The robustness of the homogeneous unit controller with respect to bounded matched perturbations is proven. The theoretical results are supported by numerical simulations.
Automatique
IFAC_paper.pdf (1.15 Mo) Télécharger le fichier
hal-04059845 , version 1 (05-04-2023)
Paternité
  • HAL Id : hal-04059845 , version 1
Andrey Polyakov. Generalized Homogeneous Unit Control. IFAC 2023 - 22nd World Congress of the International Federation of Automatic Control, Jul 2023, Yokohama, Japan. ⟨hal-04059845⟩
45 Consultations
39 Téléchargements
