Evaluating the Portability of Rheumatoid Arthritis Phenotyping Algorithms: case study on French EHRs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Previous work has successfully used machine learning and natural language processing for the phenotyping of Rheumatoid Arthritis (RA) patients in hospitals within the United States and France. Our goal is to evaluate the adaptability of RA phenotyping algorithms to a new hospital, both at the patient and encounter levels. Two algorithms are adapted and evaluated with a newly developed RA gold standard corpus, including annotations at the encounter level. The adapted algorithms offer comparably good performance for patient-level phenotyping on the new corpus (F1 0.68 to 0.82), but lower performance for encounter-level (F1 0.54). Regarding adaptation feasibility and cost, the first algorithm incurred a heavier adaptation burden because it required manual feature engineering. However, it is less computationally intensive than the second, semi-supervised, algorithm.
or_submission_32_4_1.pdf (644.7 Ko) Télécharger le fichier
hal-04069779 , version 1 (14-04-2023)
  • HAL Id : hal-04069779 , version 1
Thibaut Fabacher, Erik-André Sauleau, Noémie Leclerc, Hugo Bergier, Jacques-Eric Gottenberg, et al.. Evaluating the Portability of Rheumatoid Arthritis Phenotyping Algorithms: case study on French EHRs. Medical Informatics Europe, May 2023, Gothenburg, Sweden. pp.768-772. ⟨hal-04069779⟩
106 Consultations
35 Téléchargements
