Fed-MIWAE: Federated Imputation of Incomplete Data via Deep Generative Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Federated learning allows for the training of machine learn- ing models on multiple decentralized local datasets without requiring explicit data exchange. However, data pre-processing, including strate- gies for handling missing data, remains a major bottleneck in real-world federated learning deployment, and is typically performed locally. This approach may be biased, since the subpopulations locally observed at each center may not be representative of the overall one. To address this issue, this paper first proposes a more consistent approach to data stan- dardization through a federated model. Additionally, we propose Fed- MIWAE, a federated version of the state-of-the-art imputation method MIWAE, a deep latent variable model for missing data imputation based on variational autoencoders. MIWAE has the great advantage of being easily trainable with classical federated aggregators. Furthermore, it is able to deal with MAR (Missing At Random) data, a more challenging missing-data mechanism than MCAR (Missing Completely At Random), where the missingness of a variable can depend on the observed ones. We evaluate our method on multi-modal medical imaging data and clinical scores from a simulated federated scenario with the ADNI dataset. We compare Fed-MIWAE with respect to classical imputation methods, ei- ther performed locally or in a centralized fashion. Fed-MIWAE allows to achieve imputation accuracy comparable with the best centralized method, even when local data distributions are highly heterogeneous. In addition, thanks to the variational nature of Fed-MIWAE, our method is designed to perform multiple imputation, allowing for the quantification of the imputation uncertainty in the federated scenario.
main_MICCAI.pdf (590.17 Ko) Télécharger le fichier
hal-04069795 , version 1 (14-04-2023)
Irene Balelli, Aude Sportisse, Francesco Cremonesi, Pierre-Alexandre Mattei, Marco Lorenzi. Fed-MIWAE: Federated Imputation of Incomplete Data via Deep Generative Models. 2023. ⟨hal-04069795⟩
59 Consultations
146 Téléchargements
