Designing Medium Access Control Protocol Sequences Through Deep Reinforcement Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work aims to design protocol sequences through deep reinforcement learning (DRL). Protocol sequences are periodic binary sequences that define multiple access control among users, introduced for systems considering collision channel without feedback (CCw/oFB). In this paper, we leverage the recent advancement of DRL methods to design protocol sequences with desirable new properties, namely Throughput Maximizing User-Irrepressible (TMUI) sequences. TMUI has two specific properties: (i) user-irrepressibility (UI), and (ii) maximizing the minimum individual throughput among the users. We assumed that the transmission channel is divided into time slots and the starting time of each user in joining the system is arbitrary such that there exist random relative time offsets. We use a DRL approach to find TMUI sequences. We report the obtained TMUI protocol sequences and conduct numerical studies comparing TMUI against slotted ALOHA. Simulation results also show that the new medium access control (MAC) protocol does hold the UI property and can achieve substantially higher minimum individual user throughput, under the same system parameters.
Designing Medium Access Control Protocol Through DRL.pdf (559.94 Ko) Télécharger le fichier
hal-04070131 , version 1 (14-04-2023)
  • HAL Id : hal-04070131 , version 1
Cédric Adjih, Chung Shue Chen, Chetanveer Gobin, Iman Hmedoush. Designing Medium Access Control Protocol Sequences Through Deep Reinforcement Learning. EuCNC & 6G Summit 2023 - European Conference on Networks and Communications & 6G Summit, Jun 2023, Gothenburg, Sweden. ⟨hal-04070131⟩
136 Consultations
64 Téléchargements
