Polynomial optimization in geometric modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
In this chapter, we review applications of Polynomial Optimization techniques to Geometric Modeling problems. We present examples of topical problems in Geometric Modeling, illustrate their solution using Polynomial Optimization Tools, report some experimental results and analyse the behavior of the methods, showing what are their strengths and their limitations.
Polynomial_optimization_in_geometric_modeling.pdf (2.17 Mo) Télécharger le fichier
hal-04081849 , version 1 (25-04-2023)
  • HAL Id : hal-04081849 , version 1
Soodeh Habibi, Michal Kočvara, Bernard Mourrain. Polynomial optimization in geometric modeling. Michal Kočvara; Bernard Mourrain; Cordian Riener. Polynomial Optimization, Moments, and Applications, Springer, pp.163-186, inPress. ⟨hal-04081849⟩
102 Consultations
135 Téléchargements
