On bubble cloud growth in shock-droplet interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Investigations of shock-induced cavitation is highly challenged by the multiphase nature of the mechanisms involved. Thermodynamically well-posed multiphase numerical models accouting for phase compression and expansion however allow to elucidate the underlying physics. A description of the bubble cloud growth and its effects on the early droplet dynamics is proposed, as well as a critical discussion on the analytical predictions of the cavitation event previously reported.
ICFM_2023_KS_LBP.pdf (1.3 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04086409 , version 1 (02-05-2023)
  • HAL Id : hal-04086409 , version 1
Kevin Schmidmayer, Luc Biasiori-Poulanges. On bubble cloud growth in shock-droplet interaction. ICMF 2023 - 11th International Conference on Multiphase Flow, Apr 2023, Kobe, Japan. ⟨hal-04086409⟩
134 Consultations
42 Téléchargements
