Energy-momentum tensor in the scalar diquark model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Physical Journal C: Particles and Fields Année : 2023
We compute all the gravitational form factors in the scalar diquark model at the one-loop level using two different regularization methods. We check explicitly that all the Poincaré sum rules are satisfied and we discuss in detail the results for the trace of the energy-momentum tensor. Finally we discuss the spatial distributions of energy and pressure in two and three dimensions.
hal-04092805 , version 1 (09-05-2023)
Arturo Amor-Quiroz, William Focillon, Cédric Lorcé, Simone Rodini. Energy-momentum tensor in the scalar diquark model. European Physical Journal C: Particles and Fields, 2023, 83 (11), pp.1012. ⟨10.1140/epjc/s10052-023-12190-7⟩. ⟨hal-04092805⟩
18 Consultations
0 Téléchargements
