A Researcher's Digest of GQL
GQL (Graph Query Language) is being developed as a new ISO standard for graph query languages to play the same role for graph databases as SQL plays for relational. In parallel, an extension of SQL for querying property graphs, SQL/PGQ, is added to the SQL standard; it shares the graph pattern matching functionality with GQL. Both standards (not yet published) are hard-to-understand specifications of hundreds of pages. The goal of this paper is to present a digest of the language that is easy for the research community to understand, and thus to initiate research on these future standards for querying graphs. The paper concentrates on pattern matching features shared by GQL and SQL/PGQ, as well as querying facilities of GQL.
Base de données [cs.DB]
Licence : CC BY - Paternité
