GRAPHIT: Iterative reweighted l1 algorithm for sparse graph inference in state-space models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
State-space models (SSMs) are a common tool for modeling multi-variate discrete-time signals. The linear-Gaussian (LG) SSM is widely applied as it allows for a closed-form solution at inference, if the model parameters are known. However, they are rarely available in real-world problems and must be estimated. Promoting sparsity of these parameters favours both interpretability and tractable inference. In this work, we propose GraphIT, a majorization-minimization (MM) algorithm for estimating the linear operator in the state equation of an LG-SSM under sparse prior. A versatile family of non-convex regularization potentials is proposed. The MM method relies on tools inherited from the expectationmaximization methodology and the iterated reweighted-l1 approach. In particular, we derive a suitable convex upper bound for the objective function, that we then minimize using a proximal splitting algorithm. Numerical experiments illustrate the benefits of the proposed inference technique.
ICASSP2023_GRAPHIT_final.pdf (472.67 Ko) Télécharger le fichier
hal-04094496 , version 1 (11-05-2023)
Emilie Chouzenoux, Víctor Elvira. GRAPHIT: Iterative reweighted l1 algorithm for sparse graph inference in state-space models. ICASSP 2023 - IEEE International Conference on Acoustics, Speech and Signal Processing, Jun 2023, Rhodes (Grèce), Greece. ⟨10.1109/ICASSP49357.2023.10096021⟩. ⟨hal-04094496⟩
23 Consultations
20 Téléchargements
