Floating-point arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Numerica Année : 2023
Floating-point numbers have an intuitive meaning when it comes to physics-based numerical computations, and they have thus become the most common way of approximating real numbers in computers. The IEEE-754 Standard has played a large part in making floating-point arithmetic ubiquitous today, by specifying its semantics in a strict yet useful way as early as 1985. In particular, floating-point operations should be performed as if their results were first computed with an infinite precision and then rounded to the target format. A consequence is that floating-point arithmetic satisfies the ‘standard model’ that is often used for analysing the accuracy of floating-point algorithms. But that is only scraping the surface, and floating-point arithmetic offers much more. In this survey we recall the history of floating-point arithmetic as well as its specification mandated by the IEEE-754 Standard. We also recall what properties it entails and what every programmer should know when designing a floating-point algorithm. We provide various basic blocks that can be implemented with floating-point arithmetic. In particular, one can actually compute the rounding error caused by some floating-point operations, which paves the way to designing more accurate algorithms. More generally, properties of floating-point arithmetic make it possible to extend the accuracy of computations beyond working precision.
floatingpoint_arithmetic.pdf (870.72 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04095151 , version 1 (11-05-2023)
Sylvie Boldo, Claude-Pierre Jeannerod, Guillaume Melquiond, Jean-Michel Muller. Floating-point arithmetic. Acta Numerica, 2023, 32, pp.203-290. ⟨10.1017/S0962492922000101⟩. ⟨hal-04095151⟩
168 Consultations
1479 Téléchargements
