Word-Size RMR Trade-offs for Recoverable Mutual Exclusion - Inria - Institut national de recherche en sciences et technologies du numérique
Loading [MathJax]/jax/output/HTML-CSS/jax.js
Pré-Publication, Document De Travail Année : 2023
We present tradeoffs between RMR complexity and memory word size for recoverable mutual exclusion (RME) algorithms using arbitrary synchronization primitives. Assuming that each memory location stores w bits, we show that n-process mutual exclusion has an RMR complexity of at least Ω(min{logwn,logn/loglogn}) on the DSM and the CC model. For w=(logn)Ω(1), our lower bound asymptotically matches an upper bound by Katzan and Morrison, whose RME mutual exclusion algorithm employs w-bit fetch-and-add operations. Our lower bound is the first one that does not restrict the type of atomic operations that can be executed on a memory location.
general-rme-space-lower-bound.pdf (994 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-04098408 , version 1 (16-05-2023)
  • HAL Id : hal-04098408 , version 1
David Yu Cheng Chan, George Giakkoupis, Philipp Woelfel. Word-Size RMR Trade-offs for Recoverable Mutual Exclusion. 2023. ⟨hal-04098408⟩
75 Consultations
125 Téléchargements
More
