An algebraic framework for geometrically continuous splines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Geometrically continuous splines are piecewise polynomial functions defined on a collection of patches which are stitched together through transition maps. They are called $G^{r}$-splines if, after composition with the transition maps, they are continuously differentiable functions to order $r$ on each pair of patches with stitched boundaries. This type of splines has been used to represent smooth shapes with complex topology for which (parametric) spline functions on fixed partitions are not sufficient. In this article, we develop new algebraic tools to analyze $G^r$-spline spaces. We define $G^{r}$-domains and transition maps using an algebraic approach, and establish an algebraic criterion to determine whether a piecewise function is $G^r$-continuous on the given domain. In the proposed framework, we construct a chain complex whose top homology is isomorphic to the $G^{r}$-spline space. This complex generalizes Billera-Schenck-Stillman homological complex used to study parametric splines. Additionally, we show how previous constructions of $G^r$-splines fit into this new algebraic framework, and present an algorithm to construct a bases for $G^r$-spline spaces. We illustrate how our algebraic approach works with concrete examples, and prove a dimension formula for the $G^r$-spline space in terms of invariants to the chain complex. In some special cases, explicit dimension formulas in terms of the degree of splines are also given.
hal-04100465 , version 1 (17-05-2023)
Angelos Mantzaflaris, Bernard Mourrain, Nelly Villamizar, Beihui Yuan. An algebraic framework for geometrically continuous splines. 2023. ⟨hal-04100465⟩
34 Consultations
0 Téléchargements
