"Good Lie Brackets" for Control Affine Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider a smooth system of the form $\dot q=f_0(q)+\sum\limits_{i=1}^k u_i f_i(q)$, $q\in M,\ u_i\in\mathbb R,$ and study controllability issues on the group of diffeomorphisms of $M$. It is well-known that the system can arbitrarily well approximate the movement in the direction of any Lie bracket polynomial of $f_1,\ldots,f_k$. Any Lie bracket polynomial of $f_1,\ldots,f_k$ is good in this sense. Moreover, some combinations of Lie brackets which involve the drift term $f_0$ are also good but surely not all of them. In this paper we try to characterize good ones and, in particular, all universal good combinations, which are good for any nilpotent truncation of any system.
hal-04104558 , version 1 (24-05-2023)
Andrei Agrachev. "Good Lie Brackets" for Control Affine Systems. 2023. ⟨hal-04104558⟩
13 Consultations
0 Téléchargements
