Stochastic Pitch Prediction Improves the Diversity and Naturalness of Speech in Glow-TTS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Flow-based generative models are widely used in text-to-speech (TTS) systems to learn the distribution of audio features (e.g., Mel-spectrograms) given the input tokens and to sample from this distribution to generate diverse utterances. However, in the zero-shot multi-speaker TTS scenario, the generated utterances lack diversity and naturalness. In this paper, we propose to improve the diversity of utterances by explicitly learning the distribution of fundamental frequency sequences (pitch contours) of each speaker during training using a stochastic flow-based pitch predictor, then conditioning the model on generated pitch contours during inference. The experimental results demonstrate that the proposed method yields a significant improvement in the naturalness and diversity of speech generated by a Glow-TTS model that uses explicit stochastic pitch prediction, over a Glow-TTS baseline and an improved Glow-TTS model that uses a stochastic duration predictor.
Stochastic_Pitch_Prediction_for_Improving_the_Diversity_and_Naturalness_in_GlowTTS.pdf (281.52 Ko) Télécharger le fichier
hal-04108825 , version 1 (28-05-2023)
Paternité
  • HAL Id : hal-04108825 , version 1
Sewade Ogun, Vincent Colotte, Emmanuel Vincent. Stochastic Pitch Prediction Improves the Diversity and Naturalness of Speech in Glow-TTS. InterSpeech 2023, Aug 2023, Dublin, Ireland. ⟨hal-04108825⟩
40 Consultations
25 Téléchargements
