On Isolating Roots in a Multiple Field Extension
We address univariate root isolation when the polynomial's coefficients are in a multiple field extension. We consider a polynomial $F \in L[Y]$, where $L$ is a multiple algebraic extension of $\mathbb{Q}$.
We provide aggregate bounds for $F$ and algorithmic and bit-complexity results for the problem of isolating its roots.
For the latter problem we follow a common approach based on univariate root isolation algorithms. For the particular case where $F$ does not have multiple roots, we achieve a bit-complexity in $\tilde{\mathcal{O}}_B(n d^{2n+2}(d+n\tau))$, where $d$ is the total degree and $\tau$ is the bitsize of the involved polynomials.
In the general case we need to enhance our algorithm with a preprocessing step that determines the number of distinct roots of $F$. We follow a numerical, yet certified, approach that has bit-complexity
$\tilde{\mathcal{O}}_B(n^2d^{3n+3}\tau + n^3 d^{2n+4}\tau)$.
Calcul formel [cs.SC]
Isolating_roots_in_a_multiple_field_extension__HAL_.pdf (612.57 Ko)
Télécharger le fichier
