A global invariant for path structures and second order differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We study a global invariant for path structures. The invariant is obtained as a secondary invariant from a Cartan connection on a canonical bundle associated to a path structure. It is computed in examples which are defined in terms of reductions of the path structure. In particular we give a formula for this global invariant for second order differential equations defined on a torus .
global-invariant-final.pdf (337.26 Ko) Télécharger le fichier
hal-04121036 , version 1 (12-06-2023)
  • HAL Id : hal-04121036 , version 1
Elisha Falbel, Jose Miguel Veloso. A global invariant for path structures and second order differential equations. 2023. ⟨hal-04121036⟩
17 Consultations
24 Téléchargements
