Use of Screw Theory in Proximity-based Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this short paper, we discuss the utility of screw theory in proximity-based control. In this scheme, a task function is defined based on the proximity signals, whose regulation obtains the appropriate robotic behavior. Screw theory can be used in modelling a multi-sensor arrangement of proximity sensors. Additionally, it can also be used in identifying the set of control directions that result in identical path in sensor-space while the task is being executed.
ICRA_23_WS_Use_of_Screw_Theory_in_Proximity-based_Control.pdf (1.18 Mo) Télécharger le fichier
hal-04121340 , version 1 (07-06-2023)
Paternité
  • HAL Id : hal-04121340 , version 1
John Thomas, François Chaumette. Use of Screw Theory in Proximity-based Control. ICRA workshop - "Geometric Representations: The Roles of Modern Screw Theory, Lie algebra, and Geometric Algebra in Robotics", May 2023, London, United Kingdom. pp.1-5. ⟨hal-04121340⟩
28 Consultations
45 Téléchargements
