Learning via Wasserstein-Based High Probability Generalisation Bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Minimising upper bounds on the population risk or the generalisation gap has been widely used in structural risk minimisation (SRM) -- this is in particular at the core of PAC-Bayesian learning. Despite its successes and unfailing surge of interest in recent years, a limitation of the PAC-Bayesian framework is that most bounds involve a Kullback-Leibler (KL) divergence term (or its variations), which might exhibit erratic behavior and fail to capture the underlying geometric structure of the learning problem -- hence restricting its use in practical applications. As a remedy, recent studies have attempted to replace the KL divergence in the PAC-Bayesian bounds with the Wasserstein distance. Even though these bounds alleviated the aforementioned issues to a certain extent, they either hold in expectation, are for bounded losses, or are nontrivial to minimize in an SRM framework. In this work, we contribute to this line of research and prove novel Wasserstein distance-based PAC-Bayesian generalisation bounds for both batch learning with independent and identically distributed (i.i.d.) data, and online learning with potentially non-i.i.d. data. Contrary to previous art, our bounds are stronger in the sense that (i) they hold with high probability, (ii) they apply to unbounded (potentially heavy-tailed) losses, and (iii) they lead to optimizable training objectives that can be used in SRM. As a result we derive novel Wasserstein-based PAC-Bayesian learning algorithms and we illustrate their empirical advantage on a variety of experiments.
hal-04121624 , version 1 (08-06-2023)
Paternité
Paul Viallard, Maxime Haddouche, Umut Şimşekli, Benjamin Guedj. Learning via Wasserstein-Based High Probability Generalisation Bounds. NeurIPS 2023 - Thirty-seventh Conference on Neural Information Processing Systems, Dec 2023, New Orleans, United States. ⟨10.48550/arXiv.2306.04375⟩. ⟨hal-04121624⟩
67 Consultations
0 Téléchargements
