Filtered Residual Compression for Satellite Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Learned image compression neural networks have difficulties adapting to certain satellite image characteristics, especially high frequencies that disappear at a high bit-rate in the blur generated in the reconstruction. To answer this problem we describe a joint end-to-end trainable neural network. It is separated into a general compression network and a smaller specialised network. We train a specialized network to compress the residual part of the image to best preserve the highfrequency details present in the satellite images. The proposed model achieves higher rate-distortion performance than current lossy image compression standards and also manages to retrieve details previously poorly reconstructed.
IGARSS_2023_BACCHUS.pdf (426.25 Ko) Télécharger le fichier
hal-04125811 , version 1 (12-06-2023)
Paternité
  • HAL Id : hal-04125811 , version 1
Pascal Bacchus, Renaud Fraisse, Christine Guillemot, Aline Roumy. Filtered Residual Compression for Satellite Images. IGARSS 2023 - International Geoscience and Remote Sensing Symposium, IEEE Geoscience and Remote Sensing Society, Jul 2023, Pasadena, CA, United States. pp.1-1. ⟨hal-04125811⟩
46 Consultations
43 Téléchargements
