RFC 9407 Tetrys: An On-the-Fly Network Coding Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2023
This document describes Tetrys, which is an on-the-fly network coding protocol that can be used to transport delay-sensitive and loss-sensitive data over a lossy network. Tetrys may recover from erasures within an RTT-independent delay thanks to the transmission of coded packets. This document is a record of the experience gained by the authors while developing and testing the Tetrys protocol in real conditions. This document is a product of the Coding for Efficient NetWork Communications Research Group (NWCRG). It conforms to the NWCRG taxonomy described in RFC 8406.
rfc9407.pdf (252.79 Ko) Télécharger le fichier
Licence : Domaine public
hal-04126816 , version 1 (13-06-2023)
Domaine public
  • HAL Id : hal-04126816 , version 1
Jonathan Detchart, Emmanuel Lochin, Jérôme Lacan, Vincent Roca. RFC 9407 Tetrys: An On-the-Fly Network Coding Protocol. Internet Research Task Force (IRTF) - Request for Comments: 9407 - Category: Experimental, 2023. ⟨hal-04126816⟩
61 Consultations
26 Téléchargements
