Learning on entropy coded images with CNN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an empirical study to see whether learning with convolutional neural networks (CNNs) on entropy coded data is possible. First, we define spatial and semantic closeness, two key properties that we experimentally show to be necessary to guarantee the efficiency of the convolution. Then, we show that these properties are not satisfied by the data processed by an entropy coder. Despite this, our experimental results show that learning in such difficult conditions is still possible, and that the performance are far from a random guess. These results have been obtained thanks to the construction of CNN architectures designed for 1D data (one based on VGG, the other on ResNet). Finally, we propose some experiments that explain why CNN are still performing reasonably well on entropy coded data.
icassp2023_learning_on_entropy_coded_images_with_cnn.pdf (199.78 Ko) Télécharger le fichier
hal-04133662 , version 1 (20-06-2023)
Paternité
Rémi Piau, Thomas Maugey, Aline Roumy. Learning on entropy coded images with CNN. ICASSP 2023 - IEEE International Conference on Acoustics, Speech and Signal Processing, Jun 2023, Rhodes, Greece. pp.1-5, ⟨10.1109/ICASSP49357.2023.10095647⟩. ⟨hal-04133662⟩
23 Consultations
80 Téléchargements
