Pixel-wise Agricultural Image Time Series Classification: Comparisons and a Deformable Prototype-based Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Improvements in Earth observation by satellites allow for imagery of ever higher temporal and spatial resolution. Leveraging this data for agricultural monitoring is key for addressing environmental and economic challenges. Current methods for crop segmentation using temporal data either rely on annotated data or are heavily engineered to compensate the lack of supervision. In this paper, we present and compare datasets and methods for both supervised and unsupervised pixel-wise segmentation of satellite image time series (SITS). We also introduce an approach to add invariance to spectral deformations and temporal shifts to classical prototype-based methods such as K-means and Nearest Centroid Classifier (NCC). We show this simple and highly interpretable method leads to meaningful results in both the supervised and unsupervised settings and significantly improves the state of the art for unsupervised classification of agricultural time series on four recent SITS datasets.
Vincent_agriITSC.pdf (4.53 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04135119 , version 1 (20-06-2023)
Elliot Vincent, Jean Ponce, Mathieu Aubry. Pixel-wise Agricultural Image Time Series Classification: Comparisons and a Deformable Prototype-based Approach. 2023. ⟨hal-04135119⟩
51 Consultations
13 Téléchargements
