Efficient spectral volumetric rendering based on astrophysical assumptions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mémoires D'étudiants -- Hal-Inria+ Année : 2023
Physically accurate spectral rendering generally brings further computational complexity to RGB rendering pipelines which precludes real-time rates. In this report, we show that by building on several physical a-prioris for the spectral phe- nomena in standard astronomical scenes, we achieve to obtain a model greatly reducing the complexity of the spectral aspect for volumetric rendering - by up to 83 factor in our examples. By projecting the total local contribution on a small op- timal basis, thus providing scalability for the method, our rendering scheme then makes it possible to render a volumetric scene with any number and spectra of lights in real-time and no significant visual discrepancies.
Rapport.pdf (7 Mo) Télécharger le fichier
Slides.pdf (14.38 Mo) Télécharger le fichier
hal-04142780 , version 1 (27-06-2023)
Paternité
  • HAL Id : hal-04142780 , version 1
Julien Barrès. Efficient spectral volumetric rendering based on astrophysical assumptions. Computer Science [cs]. 2023. ⟨hal-04142780⟩
94 Consultations
52 Téléchargements
