Effective homology and periods of complex projective hypersurfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We introduce a new algorithm for computing the periods of a smooth complex projective hypersurface. The algorithm intertwine with a new method for computing an explicit basis of the singular homology of the hypersurface. It is based on Picard–Lefschetz theory and relies on the computation of the monodromy action induced by a one-parameter family of hyperplane sections on the homology of a given section. We provide a SageMath implementation. For example, on a laptop, it makes it possible to compute the periods of a smooth complex quartic surface with hundreds of digits of precision in typically an hour
effective-picard-lefschetz-theory.pdf (766.59 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04144264 , version 1 (10-01-2024)
Pierre Lairez, Eric Pichon-Pharabod, Pierre Vanhove. Effective homology and periods of complex projective hypersurfaces. 2024. ⟨hal-04144264⟩
35 Consultations
12 Téléchargements
