RULKNE: Representing User Knowledge State in Search-as-Learning with Named Entities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A reliable representation of the user's knowledge state during a learning search session is crucial to understand their real information needs. When a search system is aware of such a state, it can adapt the search results and provide greater support for the user's learning objectives. A common practice to track the user's knowledge state is to consider the content of the documents they read during their search session(s). However, most current work ignores entity mentions in the documents, which, when linked to knowledge graphs, can be a source of valuable information regarding the user's knowledge. To fill this gap, we extend RULK-Representing User Knowledge in Search-as-Learning-with entity linking capabilities. The extended framework RULK NE represents and tracks user knowledge as a collection of such entities. It eventually estimates the user knowledge gain-learning outcome-by measuring the similarity between the represented knowledge and the learning objective. We show that our methods allow for up to 10% improvements when estimating user knowledge gains.
12__CHIIR_2023___RULK_NE-camera-ready.pdf (593.14 Ko) Télécharger le fichier
hal-04152998 , version 1 (05-07-2023)
Paternité
Dima El Zein, Arthur Câmara, Célia da Costa Pereira, Andrea G. B. Tettamanzi. RULKNE: Representing User Knowledge State in Search-as-Learning with Named Entities. CHIIR 2023 - ACM SIGIR Conference on Human Information Interaction and Retrieval, Mar 2023, Austin, TX, United States. pp.388-393, ⟨10.1145/3576840.3578330⟩. ⟨hal-04152998⟩
14 Consultations
16 Téléchargements
