Towards a correctly-rounded and fast power function in binary64 arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We design algorithms for the correct rounding of the power function x y in the binary64 IEEE 754 format, for all rounding modes, modulo the knowledge of hardest-to-round cases. Our implementation of these algorithms largely outperforms previous correctly-rounded implementations and is not far from the efficiency of current mathematical libraries, which are not correctly-rounded. Still, we expect our algorithms can be further improved for speed. The proofs of correctness are fully detailed, with the goal to enable a formal proof of these algorithms. We hope this work will motivate the next IEEE 754 revision committee to require correct rounding for mathematical functions.
pow.pdf (446.59 Ko) Télécharger le fichier
hal-04159652 , version 1 (12-07-2023)
hal-04159652 , version 2 (08-02-2024)
Paternité
  • HAL Id : hal-04159652 , version 1
Tom Hubrecht, Claude-Pierre Jeannerod, Paul Zimmermann. Towards a correctly-rounded and fast power function in binary64 arithmetic. 2023. ⟨hal-04159652v1⟩
395 Consultations
196 Téléchargements
