Equilibria, Stability, and Sensitivity for the Aerial Suspended Beam Robotic System Subject to Parameter Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2023
Équilibres, stabilité et sensibilité d'un système robotique de manipulation aérienne soumis à incertitudes des paramètres.
This work studies how parametric uncertainties affect the cooperative manipulation of a cable-suspended beamshaped load by means of two aerial robots not explicitly communicating with each other. In particular, the work sheds light on the impact of the uncertain knowledge of the model parameters available to an established communication-less force-based controller. First, we find the closed-loop equilibrium configurations in the presence of the aforementioned uncertainties, and then we study their stability. Hence, we show the fundamental role played in the robustness of the load attitude control by the internal force induced in the manipulated object by non-vertical cables. Furthermore, we formally study the sensitivity of the attitude error to such parametric variations, and we provide a method to act on the load position error in the presence of the uncertainties. Eventually, we validate the results through an extensive set of numerical tests in a realistic simulation environment including underactuated aerial vehicles and sagging-prone cables, and through hardware experiments.
p2021ut_c_aerial_cable_force_uncertainty.pdf (9.94 Mo) Télécharger le fichier
Licence : Domaine public
hal-04161342 , version 1 (13-07-2023)
Paternité
Chiara Gabellieri, Marco Tognon, Dario Sanalitro, Antonio Franchi. Equilibria, Stability, and Sensitivity for the Aerial Suspended Beam Robotic System Subject to Parameter Uncertainty. IEEE Transactions on Robotics, 2023, 39 (5), pp.3977 - 3993. ⟨10.1109/TRO.2023.3279033⟩. ⟨hal-04161342⟩
54 Consultations
56 Téléchargements
