SUnAA: Sparse Unmixing using Archetypal Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Geoscience and Remote Sensing Letters Année : 2023
This paper introduces a new sparse unmixing technique using archetypal analysis (SUnAA). First, we design a new model based on archetypal analysis. We assume that the endmembers of interest are a convex combination of endmembers provided by a spectral library and that the number of endmembers of interest is known. Then, we propose a minimization problem. Unlike most conventional sparse unmixing methods, here the minimization problem is non-convex. We minimize the optimization objective iteratively using an active set algorithm. Our method is robust to the initialization and only requires the number of endmembers of interest. SUnAA is evaluated using two simulated datasets for which results confirm its better performance over other conventional and advanced techniques in terms of signal-to-reconstruction error. SUnAA is also applied to Cuprite dataset and the results are compared visually with the available geological map provided for this dataset. The qualitative assessment demonstrates the successful estimation of the minerals abundances and significantly improves the detection of dominant minerals compared to the conventional regression-based sparse unmixing methods. The Python implementation of SUnAA can be found at: https://github.com/BehnoodRasti/SUnAA.
SUnAA.pdf (967.43 Ko) Télécharger le fichier
hal-04161394 , version 1 (08-08-2023)
Paternité
Behnood Rasti, Alexandre Zouaoui, Julien Mairal, Jocelyn Chanussot. SUnAA: Sparse Unmixing using Archetypal Analysis. IEEE Geoscience and Remote Sensing Letters, 2023, 20, pp.1-5. ⟨10.1109/LGRS.2023.3284221⟩. ⟨hal-04161394⟩
50 Consultations
68 Téléchargements
