Multiscale uncertainty quantification of complex nonlinear dynamic structures with friction interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jie Yuan
  • Fonction : Auteur
  • PersonId : 1128405
This work aims to investigate the interest in multi-scale uncertainty quantification for nonlinear dynamic systems with friction interfaces. Indeed, such structures experience uncertainties at different time and space scales due to the friction interface. The focus of this work is to quantify and link the uncertainties from friction interfaces at different scales to the nonlinear dynamic response of the structure. A multi-scale kriging approach is employed to propagate the uncertainty. An industrial test rig for dovetail joints will be used as a test case to demonstrate the proposed methodology.
Denimal_Yuan_Nodycon2023.pdf (288.48 Ko) Télécharger le fichier
hal-04166228 , version 1 (19-07-2023)
Paternité
  • HAL Id : hal-04166228 , version 1
Enora Denimal, Jie Yuan. Multiscale uncertainty quantification of complex nonlinear dynamic structures with friction interfaces. Nodycon 2023 - Third International Nonlinear Dynamics Conference, Jun 2023, Rome, Italy. pp.1. ⟨hal-04166228⟩
29 Consultations
12 Téléchargements
