Parametric optimization of fold bifurcation points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this work is to optimize the parameters of a mechanical system in order to force fold bifurcation points to appear at targeted frequencies. To this end, an original harmonic balance-based optimization procedure is developed. Functions similar to those employed during bifurcation tracking analyses are used to characterize fold bifurcations in the objective function. The proposed approach is illustrated on a Duffing oscillator with cubic nonlinearity.
Melot_et_al_Nodycon2023.pdf (158.91 Ko) Télécharger le fichier
hal-04166242 , version 1 (19-07-2023)
Paternité
  • HAL Id : hal-04166242 , version 1
Adrien Mélot, Enora Denimal, Ludovic Renson. Parametric optimization of fold bifurcation points. Nodycon 2023 - Third International Nonlinear Dynamics Conference, Jun 2023, Rome, Italy. pp.1. ⟨hal-04166242⟩
23 Consultations
35 Téléchargements
