Fiber crosslinking drives the emergence of order in a 3D dynamical network model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Royal Society Open Science Année : 2024
The Extra-Cellular-Matrix (ECM) is a complex interconnected 3D network that provides structural support for the cells and tissues and defines organ architecture key for their healthy functioning. However, the intimate mechanisms by which ECM acquire their 3D architecture are still largely unknown. In this paper, we address this question by means of a 3D individual based model of interacting fibers able to spontaneously crosslink or unlink to each other and align at the crosslinks. We show that such systems are able to spontaneously generate different types of architectures. We provide a thorough analysis of the emerging structures by an exhaustive parametric analysis and the use of appropriate visualization tools and quantifiers in 3D. The most striking result is that the emergence of ordered structures can be fully explained by a single emerging variable : the proportion of crosslinks in the network. This simple variable becomes an important putative target to control and predict the structuring of biological tissues, to suggest possible new therapeutic strategies to restore tissue functions after disruption, and to help in the development of collagen-based scaffolds for tissue engineering. Moreover, the model reveals that the emergence of architecture is a spatially homogeneous process following a unique evolutionary path, and highlights the essential role of dynamical crosslinking in tissue structuring.
main_v8.pdf (16.05 Mo) Télécharger le fichier
hal-04168503 , version 1 (21-07-2023)
hal-04168503 , version 2 (27-09-2023)
  • HAL Id : hal-04168503 , version 2
Pauline Chassonnery, Jenny Paupert, Anne Lorsignol, Childérick Séverac, Marielle Ousset, et al.. Fiber crosslinking drives the emergence of order in a 3D dynamical network model. Royal Society Open Science, In press. ⟨hal-04168503v2⟩
71 Consultations
10 Téléchargements
