Metadatamatic: A Web application to Create a Dataset Description - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article introduces Metadatamatic, an open-source, online, user-friendly tool for generating the description of a knowledge base. It supports the description of any RDF dataset via a user-friendly web form that does not require prior knowledge of the vocabularies begin used, and can enrich the description with automatically generated statistics if the dataset is accessible from a public SPARQL endpoint. We discuss the models and methods behind the tool, and present some initial results suggesting that Metadatamatic can help in increasing the visibility of public knowledge bases.
Web
_DeKaLoG__Metadatamatic___TheWebConf_Poster-2.pdf (512.26 Ko) Télécharger le fichier
hal-04171196 , version 1 (26-07-2023)
Pierre Maillot, Olivier Corby, Catherine Faron, Fabien Gandon, Franck Michel. Metadatamatic: A Web application to Create a Dataset Description. WWW '23 - The ACM Web Conference 2023, Apr 2023, Austin TX, United States. pp.123-126, ⟨10.1145/3543873.3587328⟩. ⟨hal-04171196⟩
40 Consultations
23 Téléchargements
