Handling Non-Visible Referents in Situated Visualizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on Visualization & Computer Graphics (TVCG) Année : 2023
Ambre Assor
Arnaud Prouzeau
Martin Hachet
Pierre Dragicevic
Situated visualizations are a type of visualization where data is presented next to its physical referent (i.e., the physical object, space, or person it refers to), often using augmented-reality displays. While situated visualizations can be beneficial in various contexts and have received research attention, they are typically designed with the assumption that the physical referent is visible. However, in practice, a physical referent may be obscured by another object, such as a wall, or may be outside the user's visual field. In this paper, we propose a conceptual framework and a design space to help researchers and user interface designers handle non-visible referents in situated visualizations. We first provide an overview of techniques proposed in the past for dealing with non-visible objects in the areas of 3D user interfaces, 3D visualization, and mixed reality. From this overview, we derive a design space that applies to situated visualizations and employ it to examine various trade-offs, challenges, and opportunities for future research in this area.
Techniques_for_situated_visualizations_in_the_case_of_non_visible_physical_referents (3).pdf (5.63 Mo) Télécharger le fichier
hal-04176381 , version 1 (03-08-2023)
Paternité
  • HAL Id : hal-04176381 , version 1
Ambre Assor, Arnaud Prouzeau, Martin Hachet, Pierre Dragicevic. Handling Non-Visible Referents in Situated Visualizations. Transactions on Visualization & Computer Graphics (TVCG), 2023. ⟨hal-04176381⟩
105 Consultations
227 Téléchargements
