Signal reconstruction using determinantal sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We study the approximation of a square integrable function from a finite number of its evaluations at well-chosen nodes. The function is assumed to belong to a reproducing kernel Hilbert space (RKHS), the approximation to be one of a few natural finite-dimensional approximations, and the nodes to be drawn from one of two probability distributions. Both distributions are related to determinantal point processes, and use the kernel of the RKHS to favor RKHS-adapted regularity in the random design. While previous work on determinantal sampling relied on the RKHS norm, we prove mean-square guarantees in L 2 norm. We show that determinantal point processes and mixtures thereof can yield fast rates, and that they shed some light on how the rate changes as more smoothness is assumed, a phenomenon known as superconvergence. Besides, determinantal sampling generalizes i.i.d. sampling from the Christoffel function, a standard in the literature. In particular, determinantal sampling guarantees the so-called instance optimality property for a smaller number of function evaluations than i.i.d. sampling.
article.pdf (835.66 Ko) Télécharger le fichier
hal-04181079 , version 1 (18-08-2023)
  • HAL Id : hal-04181079 , version 1
Ayoub Belhadji, Rémi Bardenet, Pierre Chainais. Signal reconstruction using determinantal sampling. 2023. ⟨hal-04181079⟩
94 Consultations
96 Téléchargements
