The ORACLES database - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2022
This experimental database gives access to both the processed and the raw (instantaneous) velocity data measured by 2-component laser Doppler velocimetry on the ORACLES test facility. It contains more than 55000 files. The access to the raw data gives the opportunity to the end-user to re-process them according to his needs. The processed files are cast in a Tecplot compatible format. The files headers are meaningful so that these files can also be read by other means (text editor, specific routines…). All the necessary technical information regarding these data can be found in the directory “Documents” where are present: 1) the related paper (authors’ version) published in 2009 in Flow Turbulence and Combustion (82:155-183), 2) the PhD thesis of Phuc-Danh Nguyen (in French) and 3) the complete layout of the database. Numerous “ReadMeFirst” files are also provided in the sub-directories to explain wherever needed the content of the related files.
Fichier non déposé
hal-04186197 , version 1 (23-08-2023)
Paternité
Pascal Bruel, Phuc-Danh Nguyen. The ORACLES database. 2022, ⟨10.5281/zenodo.7029888⟩. ⟨hal-04186197⟩
18 Consultations
0 Téléchargements
