On annular short-time stability conditions for generalized Persidskii systems
This paper studies the trajectory behavior evaluation for generalized Persidskii systems with an essentially bounded input on a finite time interval. Also, the notions of annular settling and output annular settling for general nonlinear systems are introduced. We propose conditions for annular short-time stability, short-time boundedness with a nonzero initial state, annular settling, and output annular settling for a class of Persidskii systems. These conditions are based on the verification of linear matrix inequalities. An application to recurrent neural networks illustrates the usefulness of the proposed notions and conditions.
On_annular_short_time_stability_conditions_for_generalized_Persidskii_systems___R2.pdf (516.7 Ko)
Télécharger le fichier
