Development and validation of an interpretable machine learning-based calculator for predicting 5-year weight trajectories after bariatric surgery: a multinational retrospective cohort SOPHIA study
Développement et validaiton d'un modèle d'apprentissage automatique interprétable pour la prédiction de la trajectoire de poids à 5 ans après chirurgie bariatrique : une étude rétrospective SOPHIA d'une cohorte multinationale
Background
Weight loss trajectories after bariatric surgery vary widely between individuals, and predicting weight loss before the operation remains challenging. We aimed to develop a model using machine learning to provide individual preoperative prediction of 5-year weight loss trajectories after surgery.
Methods
In this multinational retrospective observational study we enrolled adult participants (aged ≥18 years) from ten prospective cohorts (including ABOS [NCT01129297], BAREVAL [NCT02310178], the Swedish Obese Subjects study, and a large cohort from the Dutch Obesity Clinic [Nederlandse Obesitas Kliniek]) and two randomised trials (SleevePass [NCT00793143] and SM-BOSS [NCT00356213]) in Europe, the Americas, and Asia, with a 5 year followup after Roux-en-Y gastric bypass, sleeve gastrectomy, or gastric band. Patients with a previous history of bariatric surgery or large delays between scheduled and actual visits were excluded. The training cohort comprised patients from two centres in France (ABOS and BAREVAL). The primary outcome was BMI at 5 years. A model was developed using least absolute shrinkage and selection operator to select variables and the classification and regression trees algorithm to build interpretable regression trees. The performances of the model were assessed through the median absolute deviation (MAD) and root mean squared error (RMSE) of BMI.
Findings
10 231 patients from 12 centres in ten countries were included in the analysis, corresponding to 30 602 patient-years. Among participants in all 12 cohorts, 7701 (75•3%) were female, 2530 (24•7%) were male. Among 434 baseline attributes available in the training cohort, seven variables were selected: height, weight, intervention type, age, diabetes status, diabetes duration, and smoking status. At 5 years, across external testing cohorts the overall mean MAD BMI was 2•8 kg/m² (95% CI 2•6-3•0) and mean RMSE BMI was 4•7 kg/m² (4•4-5•0), and the mean difference between predicted and observed BMI was-0•3 kg/m² (SD 4•7). This model is incorporated in an easy to use and interpretable web-based prediction tool to help inform clinical decision before surgery.
Interpretation
We developed a machine learning-based model, which is internationally validated, for predicting individual 5-year weight loss trajectories after three common bariatric interventions.
22tldig1227.pdf (1.42 Mo)
Télécharger le fichier
22TLDig1227_Appendix.pdf (1.53 Mo)
