Sparse GEMINI for joint discriminative clustering and feature selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Feature selection in clustering is a hard task which involves simultaneously the discovery of relevant clusters as well as relevant variables with respect to these clusters. While feature selection algorithms are often model-based through optimised model selection or strong assumptions on p(x x x), we introduce a discriminative clustering model trying to maximise a geometry-aware generalisation of the mutual information called GEMINI with a simple 1 penalty: the Sparse GEMINI. This algorithm avoids the burden of combinatorial feature subset exploration and is easily scalable to high-dimensional data and large amounts of samples while only designing a clustering model p θ (y|x x x). We demonstrate the performances of Sparse GEMINI on synthetic datasets as well as large-scale datasets. Our results show that Sparse GEMINI is a competitive algorithm and has the ability to select relevant subsets of variables with respect to the clustering without using relevance criteria or prior hypotheses.
2302.03391.pdf (432.21 Ko) Télécharger le fichier
hal-04195208 , version 1 (04-09-2023)
Louis Ohl, Pierre-Alexandre Mattei, Charles Bouveyron, Mickaël Leclercq, Arnaud Droit, et al.. Sparse GEMINI for joint discriminative clustering and feature selection. 2023. ⟨hal-04195208⟩
20 Consultations
23 Téléchargements
